» Worms
Companies in Worms
Cleveland Gear Co.
Cone Drive
David Brown Santasalo
Delroyd Worm Gear
Desch Canada Ltd.
Dorris Gear Drives
Dunkermotoren USA Inc.
Elliott Manufacturing
Excel Gear, Inc.
FMC Engineering
Framo Morat Inc.
Gayatri Gear Industries
Gear Motions, Inc.
GearTec
7
