» Segments
Companies in Segments
Central Gear & Machine
Cogmatic
David Brown Santasalo
Delta Gear Corp.
Excel Gear, Inc.
Forgital Group
GearTec
Houston Pump and Gear
IGW Industry Division
KHK USA Inc
Koro Industries, Inc.
Martin Sprocket & Gear
Mini Gears (Stockport) Ltd.
Perry Technology Corporation
