» Internal Gears
Companies in Internal Gears
Mini Gears (Stockport) Ltd.
Minsk Gear Works
MMR Precision Gears
Moventas Ltd.
NDE Clarke Pitchline Ltd
Nichiei Company, Ltd.
Nidec-Shimpo Corporation
Niebuhr Gears
Ontario Gear and Spline
P. G. DRIVE
Perry Technology Corporation
PIC Design
Precipart
Precision Arrow Gear Co.
Prozamet
Pulsgetriebe GmbH & Co. KG
7
