Rolling-element bearings are high-precision components that need to be stored and handled carefully to perform as designed. Proper storage and
handling of a bearing before, during
and after installation is important because once debris enters a bearing, it
reduces the life.
Wind is a form of solar energy.
Winds are caused by the uneven heating
of the atmosphere by the sun, the
irregularities of the earth’s surface, and rotation of the earth. Wind Turbines
convert the kinetic energy in wind into
mechanical power.
Richard (RJ) Seguin, CBS and technical
sales representative at AMI Bearings,
explains how his bearing expertise tripled
the life of a customer’s bearings.
