Schaeffler introduced a Wind Power Standard for wind turbine bearings more than ten years ago, which considers the high demands on the reliability of turbines and associated components. This standard for products and processes ensures that wind turbine bearings are subject to the highest quality standards, as also implemented, for example, in the automotive industry, and in the aviation and aerospace sectors. The start of the year marked the manufacture and delivery of the millionth bearing by Schaeffler in accordance with the Wind Power Standard.
As the U.S. member body to the International Organization for Standardization (ISO), the American National Standards Institute (ANSI) seeks comments by June 30 on a draft proposal for a new ISO technical committee on mechanical energy storage technology.
Intellidrives EtherNet/IP compatible Motion is a scalable and comprehensive solution that provides a common application interface and services for general purpose I/O and motion control that is fully compatible with standard Ethernet/IP topologies, minimizing integration effort with Ethernet/IP-based PLCs.
Prepared by members of the AGMA Flexible Coupling Committee
June 6, 2022
The technical division of AGMA directs the committees that develop and maintain standards and information sheets pertaining to the gear industry. Although often viewed as an accessory for gearboxes, flexible couplings are critical components of any machinery system, since they connect two separate pieces of rotating equipment. The Flexible Coupling Committee is responsible for 12 standards and one information sheet that are specific to flexible couplings. Six of those standards encompassing three subjects will be highlighted in this article.
