Plastic Metric Gear, Metal Reinforced Plastic Gear July 12, 2007 An expanded line of Modulel, 2, 2.5, and 3 molded-plastic gears from Quality Transmission Components offer designers the best of both wor...Read More
Flexible Molded Duracon and Steel Racks July 12, 2007 A new series of 7 flexible molded Duracon and steel racks introduced by Quality Transmission Components can run with standard ...Read More
Spur Gears, Metric Gears, Gears with Internal Shafts July 12, 2007 These 20 degree Pressure Angle pinion shafts are made of S45C (AISI 1045) steel and feature induction hardened and ground teeth which are...Read More
Belt Tensioners and Chain Tensioners-Zetasassi July 12, 2007 QTC's Econobelt line includes over 330 Zetasassi belt and chain tensioners which improve performance by keeping constant tension. The...Read More
Big Kaiser's Boring Tools Allows Users to Make Incremental Adjustments July 11, 2007 BIG Kaiser Precision Tooling Inc. introduces a patent-pending new series of Kaiser boring tools. The new series has adjusting resolu...Read More
House Positioning System at AACC Meeting/Clinical Lab Expo July 10, 2007 Parker Hannifin's PROmech series of linear actuators come completely assembled and tested and include linear bearings, drive screws, ...Read More
Sick Stegmann's Programmable Encoders Designed for Miniaturized Applications July 10, 2007 Sick Stegmann Inc. introduced the DiCoder CKS 36 programmable motor feedback system. The user-programmable DiCoder CKS36 provides r...Read More
Helical Gears & Ground Helical Gears, Helical Gear July 10, 2007 QTC offers all types of Helical Gears and Ground Helical Gears. Quality Transmission Co. offers over 230 standard Helical Gear options fo...Read More
Timing Belts, Fiberglass Reinforced Neoprene July 10, 2007 The Econobelt Line features timing belts in 11 different profiles. Made from fiberglass reinforced Neoprene, these belts are available in...Read More
AAC's New Heavy Duty Stainless Steel Vibration Mounts Designed for Corrosive Environments July 9, 2007 A new series of 3 heavy-duty base mounted vibration and shock isolators by Advanced Antivibration Components feature stainless steel mesh...Read More
