In addition to traditional commercial sprocket offerings, PEER Chain & Sprockets recently announced it can custom bore any size sprocket that has an existing keyway and deliver them within days of an order placement.
Since taking over as CEO of Solve Industrial Motion Group in June 2024, Ernie Lauber has focused on continuous improvement, predictive maintenance and growing the legacy brands within Solve.
Combining brands such as IPTCI, MasterDrive, PTI and TRITAN together with the LMS, SST, SPB-USA and USA Roller product lines, Solve Industrial Motion Group is a provider of high-quality metric and American Standard power transmission components and industrial-grade bearings.
Drew Beadle, vice president of operations of Waukegan, IL-based PEER Chain & Sprockets has been named the company’s new president, effective January 2025.
Incorporating electromagnetic clutches into industrial applications brings numerous advantages for enhancing system reliability, functionality, and safety. KEB’s Combinorm power on clutches provide a critical solution by ensuring parts of a machine can engage and disengage as needed, particularly in emergencies.
Ruland has released mountable shaft collars with face holes for applications where the shaft collar needs to be directly mounted to a component such as a pulley, sprocket, or metallic plate. The shaft collars are available with drilled face holes that give the user flexibility in mounting hardware, or tapped holes that match the standard screw threading of the collar for ease of installation.
Gates Industrial Corporation continues to invest in and has expanded its Carbon Drive product portfolio. The company is introducing next-generation belts and other components to enable advances in bicycle drivetrain design and meet growing global demand.
Chain and sprocket drives of one form or another have been driving machines and
conveying materials for over a thousand years. The chain manufacturing industry has developed numerous types and sizes of drive chains. Although it is a mature form of power transmission, there are still many industrial applications for which drive chain is suited. It is economical, resistant to shock loads, easy to install, has the ability to transmit high torque, operates in hostile environments, and is efficient. Chain and sprocket drives are highly engineered and manufactured within close tolerances.
At the recently concluded Automate 2019 and Promat trade shows (held in Chicago in April), we saw a lot of new technology aimed at making factories more efficient and productive.
