Servo Technology has gone through various key stages of evolution, from the Power Transistors (Servo 1.0) and DSP/Microprocessor (Servo 2.0) to the Integrated Packaging (Servo 3.0) and Industrial Network (Servo 4.0). We are now entering the new era in servo evolution called Servo 5.0, where the intelligence and connectivity, in align with the emerging Industry 4.0 effort, are now required in the traditional servo control products.
The Factory Automation (FA) Integrated Selection Tool allows customers to plan and configure their Mitsubishi Electric machines, resulting in a downloadable Bill of Materials (BOM).
Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servo motor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
The 2023 SPS trade fair in Nuremberg represented an important opportunity for Bonfiglioli to showcase its experience and expertise for industrial automation. This included mechatronic solutions specifically designed for packaging, intralogistics, robotics and IoT applications.
Conveying parcel delivery with no system downtime is accomplished with speed and accuracy using Miki Pulley CSZ Clutches. Conveyors continuously operate via servomotor power by way of a V-belt. The system automatically switches on/off as programmed when engaged by the CSZ Clutches.
