Neugart refines its range of coaxial planetary gearboxes: Effective immediately, the manufacturer also offers a gear ratio i=8 for its precision gearboxes with helical gearing. Thus, the gear ratio range now extends from i=3 to i=100.
Rolls-Royce is pioneering the UltraFan engine family architecture containing a planetary gearbox in a power range of 15 to 80 megawatts. To increase the efficiency of the UltraFan, a planetary gearbox is introduced between fan and intermediate pressure compressor. This enables running the turbine to rotate faster and allows a reduced fan speed.
In planetary gear systems of high power density and high gear ratio, helical gears create undesirable tilting moments on the planet gears; therefore, spur gears are still preferred for planetary gears -- a special challenge with respect to noise. Specifically, the different behavior of planetary gears with sequential and symmetric gear mesh is explained in this paper.
