When it comes to twisting and bunching wire and cable, consistency is key. For example, the amount of insulation required for residential wiring depends on the wire’s lay — the distance between its twists, which is also known as the pitch. Without tight control during the wire bunching process, lay variations occur. As a result, the wire will require more insulation than necessary, raising its cost. A differential gearbox can drive rotating components in a single-twist buncher to provide a more uniform lay, using less power at a lower cost than a two-motor approach.
Andantex USA Inc. will be renamed Redex USA Inc., according to Thomas Osygus, vice president of sales and marketing, Redex USA. "Our name is changing, but we will continue to offer the same high-quality motion control systems you’ve come to expect from us for over 40 years."
The earliest example of a gear train dates to at least 2,000 B.C. when Chinese engineers built a chariot that used a complex planetary mechanism made of wooden gears to let a dragon head continuously point south when driven around (Ref. 1). In Greece, a surprisingly advanced Antikythera gearbox mechanism, incorporating at least 37 precisely crafted bronze gears, was built years later, between 205–60 B.C. (Ref. 2).
The New Year’s Ball Drop wouldn’t be possible without a sophisticated electromechanical system that must operate reliably during the most critical 60 seconds of the year.
April 6, 2023
More than a billion people around the world unite to ring in the New Year, their eyes set upon the glittering New Year’s Ball in Manhattan. Thousands are gathered at Times Square — the famed “Bow Tie” of Midtown — braving the December cold and peering through glasses with numerically shaped frames. Millions more tune in from their various screens at home. With so much riding on its descent, the Ball, along with the mechanical and electrical systems responsible for its operation, must operate like clockwork.
Bonfiglioli is convinced that around 50 percent of all new self-propelled construction machines will be either electrically or hybrid driven by 2030. So, it is high time for the globally active group based in Bologna, Italy, to take on the electric pioneering role in the machine groups that have previously been dominated by hydraulics. At Bauma 2022, the company presented the current options for electric drive technology for construction machinery.
Stober Relies on FVA Workbench for Drive Verification
September 30, 2022
Stöber Antriebstechnik GmbH + Co. KG rely on the FVA-Workbench for dimensioning and verification of their drives. The calculation and simulation software allows Stöber engineers to develop their innovative gear unit solutions more quickly and efficiently. The result: higher quality products.
Axially space-saving, economical, IP65-compliant and designed for high radial and axial forces at the output: The Neugart WPLHE combines all the advantages of the successful PLHE, as a right-angle variant.
