Ruland Manufacturing now offers rigid couplings with inch-to-metric bores as a standard product, giving users a wider range of off-the-shelf couplings. This expansion is the latest addition to the company's inch-to-metric, standard coupling product line that includes seven types of motion-control couplings and universal joints. Instead of re-machining or ordering custom-made couplings, using off-the-shelf, inch-to-metric rigid couplings saves time and money.
NSK has developed HTF-SRM Ball Screws, a high-speed, heat-resistant version of its high-load drive ball screws, ideal for high-cycle, thin-wall molding in electric injection molding machines.
The cylindrical die rolling process can produce helical, axial, and annular forms on shaft-like parts at high rates of speed with precision tolerances.
Why use the rolling process to produce high accuracy lead screws, actuator screws, and other power transmission components rather than traditional cutting processes such as turning, grinding, milling, whirling, or hobbing? Rolling processes and cutting processes both produce a precise form on the workpiece. But if the form geometry, tolerances, and material selection allow, rolling is the process to beat. Speed, surface finish, fatigue strength, precision, dimensional stability, and material savings are some of the primary advantages realized when the rolling process is applied.
Schneeberger highlighted its precision linear positioning and motion systems, solutions, and deep engineering expertise at Automate 2023. The company featured its MINIRAIL miniature guideways, MONORAIL AMS distance measuring system, gear racks, linear and linear roller guideways, SLA Actuators, mineral cast machine foundations, and more.
Motion Plus has signed a landmark agreement with NSK Ltd., a global leader in high quality automation and bearing products. This strategic partnership will facilitate the distribution of NSK's superior automation products through Motion Plus's storefront where a customer can use filters to easily select the right stocked or custom-made product.
When selecting couplings for precise motion applications there are often questions about the most suitable approach for optimizing both performance and economy.
April 6, 2023
To determine whether a machine screw jack or ball screw jack is the right fit for your application, Thomson and Motion engineers offer the following application parameters early in the design phase.
PBC Linear has expanded its comprehensive portfolio to include Miniature Metric Ball Screw Assemblies. Building on their lead screw technology, this combination of precision-rolled screw and compact nut is driving exceptional performance from an economical package. Manufacturers of sophisticated laboratory equipment, medical devices, semiconductors, and other automation applications will find these high-precision ball screws a valued solution to their small-scale linear motion needs.
