  • TOPICS
    • Design
    • Manufacturing
    • Applications
    • Components
    • Industry
    • MRO
  • MAGAZINE
    • Current Issue
    • Departments
    • Archives
    • Subscribe
    • Advertise
  • NEWSLETTER
  • VIDEO
    • Power Transmission Engineering TV
  • BLOGS
    • Revolutions
    • Editors Choice
    • Motor Matters with George Holling
    • Bearings with Norm
  • BUYER'S GUIDE
  • NEWS and EVENTS
    • Product News
    • Industry News
    • Events
  • Advertising
    • Brand Awareness
      • Print: Display Advertising
      • Print: Engineering Showcase
      • Online: Web Banners & Keyword Banners
      • Online: Sponsored Content (Native Advertising)
      • E-mail: Custom, White Papers & Webinars
      • Email: Sponsored Content (Native Advertising)
    • Response & Lead Generation
      • E-Mail: Sponsored Content (Native Advertising)
      • E-mail: Newsletters
      • Online: Buyers Guide
    • Print
      • Print: IMTS/Hannover Messe USA Showstoppers (September 2022)
      • Print: Buyers Guide
      • Print: Engineering sMart
      • Print: Specifications
    • Online
      • Online: Web Banners and Keyword Banners
      • Online: Specifications
    • E-Mail
      • E-mail: Sponsored Content (Native Advertising)
      • E-mail: Specifications
    • Special Promotions
      • Print: Showstoppers(IMTS/Hannover Messe USA)
  • Contact Us
  • AGMA
    • Membership
    • Events
    • Education
    • Emerging Technology
    • AGMA Media
      • Gear Technology
      • Gear Technology India
    • Standards
Subscribe
  • Sign In
  • Create Account
  • Sign Out
  • My Account
Home » Design Takes on a More Holistic Scope
August 3, 2022
George Holling
In the past, we designed motors and drives separately from the mechanical system, and then we integrated suitable components to make a system work. Increasingly, though, the design focuses more on the overall system aspect and system integration, which makes the design of customized components more challenging.
In this article, we will use examples of specific software tools, and it should be noted that these are just that: examples. For many of these tools, multiple similar and good software packages exist that can be used.
As we closed out the 1990s, we had already observed a change where computer design tools were experiencing more widespread use for mechanical, electronic, magnetic motor and overall system design.
Mechanical CAD packages and 3D models started to cement their role in the design process to ensure that all of the components would fit in the final design. These tools also could generate all the information for the CNC machines so that prototype and production parts and molds could be made directly to avoid errors when transitioning from the design to the build phase. Examples are Solidworks, AutoCAD, Inventor, CATIA, CREO and others.
Since then these mechanical design suites have become more powerful, and they allow for many additional design functionalities, such as strength analysis where weaknesses and stress points in the design are analyzed and flagged to ensure that the design yields a reliable solution. While some of the above packages, i.e., Solidworks, have added features to help analyzing strength, etc., a new generation of simulation tools has evolved to model the whole system, such as ANSYS.  These software packages do not only analyze the mechanical system, e.g., strength, vibration, critical frequencies, fatigue, but they can also analyze the heat transfer, magnetics and  even fluid dynamics for the design of fans, propellers and airflow analysis (heatsink design).
In automotive and military designs, we must use such integrated design tools for thermal management, strength analysis and critical frequencies prior to even prototyping to maintain fast, efficient and cost effective design cycles.
The main drawback is that these integrated software packages are expensive to purchase and maintain and that they require extensive training and knowledge to ensure accurate results.
For motor design (magnetics), we started out with two parallel approaches that are still used today: the finite element software (FEA) which was introduced in the 1980s by Cedrat, Infolytica and A.O. Smith, and in-parallel macro modelers, which break down the magnetic circuit and iteratively solve simplified equations.  SPEED software was widely popular and is used by several of our customers, and SPEED also has an integrated FEA option that allows for fine tuning of the magnetic curves, which can yield improved accuracy of the results.
In the past, we used  SPEED software almost exclusively for our motor designs, and we found that the actual motor prototype delivered less efficiency than what the SPEED software had predicted, especially when designing high-rpm motors and those with low phase inductances even when we used the internal FEA module that SPEED offers to adjust the BH curves. When designing synchronous reluctance motors, SPEED appears to greatly overstate both the projected power output and efficiency.
We also noticed discrepancies in the projected motor efficiencies when using FEA software packages, especially when the excitation waveforms are generated via pulse width modulation (PWM). In many cases FEA-based design tools only describe the waveform, and they often rely on an AC analysis which allows solving the FEA much faster compared to a full transient analysis.
However, we have found it necessary to model the current waveform generation and its interaction with the motor magnetics in much greater detail and to perform a full transient analysis to accurately predict all the projected motor losses. We have found the use of broader system modeling tools, i.e., MATLAB, to be advantageous. They allow for us to easily and accurately model and co-simulate our control system and power switches, and we can also design the required control algorithms and automatically convert these into software for our embedded microcontrollers and digital signal processors.
Ever since we incorporated the accurate modeling of the PWM motor controller and excitation waveforms, we have been able to accurately predict the actual motor performance and, most importantly, its efficiency, which has been validated by testing over many motor designs. Thus, we consider co-simulation a key requirement for accurate motor design and performance prediction. Fortunately, most FEA and system analysis software packages offer a MATLAB interface to allow for easy co-simulation.
For the design of the power electronics, we use lower-level circuit analysis tools such as SPICE, giving us valuable insight into the inner workings of the controller and how we can efficiently drive the main power switches, which has become significantly more important as we are shifting from standard silicon-based technologies to wide-bandgap devices: silicon carbon (SiC) and gallium nitride (GaN). Furthermore, we are increasingly designing controllers that can operate in high ambient temperatures (up to 160°C/320°F) for military applications and for motor controllers integrated into the motor housing. Using these tools, we have developed our own driver stages that can switch wide-bandgap devices in the nanosecond range to design drives with almost 99% operating efficiency.
We can now use the co-simulation to solve very complex problems, such as magnetic bearing stabilization, acoustic noise control of electric motors and vibration-free propulsion, which involves integrating the electronic controls with the motor, the power electronics and the mechanical structure. Thus, we can be assured that the system will function as specified once we build the actual hardware.
In some cases, the use of this holistic approach also impacts design decisions. One such example was a traction drive with integral gears where a selection needed to be made between two different gear ratios: X and Y. There were some low-speed efficiency advantages for using ratio Y, but a full mechanical analysis revealed that ratio X would require less internal support and offer higher safety margins. Based on this analysis, ratio X was chosen. While such an analysis is not inherently novel, the use of an integrated analysis tool suite allowed us to construct and optimize a single model and simultaneously gain all the relevant information about magnetic performance, thermal management, critical frequencies and the mechanical strength. Any optimizations could be made quickly and simultaneously using a single model to obtain the desired magnetic performance, weight reduction and optimized cooling channels while assuring strength and thermal management. In the past, the model may have been bounced back and forth between different engineers, which would add significant amounts of design time and expenses.
Below we will give some examples of data obtained for a series of different analyses. One important aspect is the accuracy of modern FEA analysis. In Figure 1 we show the comparison of a static torque curve that was obtained from two different FEA software packages and how closely the results from the different software packages match.
Holling-Fig1.jpgFigure 1 Comparison of static torque curves from two different FEA softwares.
In Figure 2, we show the results of the internal operating temperatures of an automotive water pump. In this analysis we model all: the motor, the integral drive and the coolant flow. We analyzed the transient thermal behavior at 85°C ambient temperature. The picture in Figure 2 was taken after six minutes of operation.
Holling-Fig2.jpgFigure 2 Thermal analysis of an automotive brushless motor water pump.
In Figure 3, we show the internal rotor stresses in a synchronous reluctance motor at 15,000 rpm.
Holling-Fig3.jpgFigure 3 Rotor stresses at 15,000 rpm.
In Figure 4, we show the surface stresses due to the magnetic fields in a brushless PM motor.
Holling-Fig4.jpgFigure 4 Surface stresses in brushless motor due to magnetic forces.
Figure 5 shows the resulting sound pressure at the outside of the motor enclosure that these surface stresses generate at certain harmonic frequencies. A more complex analysis will also consider shaft displacements and vibrations.
Holling-Fig5.jpgFigure 5 Radiated sound pressure at f=2,360 Hz due to magnetic forces.
All of the above examples are based on the simultaneous analysis of a common model for magnetic performance (torque, efficiency); thermal analysis, which feeds back into the copper losses; mechanical analysis (strength), which takes into consideration the forces between the stator and the rotor and also the acoustic noise and many other important data points of the system performance, e.g., critical frequencies, bending moments, etc.
After the initial learning curve, it requires little extra effort to simultaneously solve for a multitude of physical characteristics of a given design far beyond the basics of torque and efficiency.  In a modern design environment, we must take a more holistic view of the design task and analyze a multitude of physics simultaneously to quickly generate accurate and optimized designs for our applications.
Motor Design Motor Efficiency Motors Technical Articles
  • Download This Article
  • Related Articles
    Putting the Brakes on Supply Chain Issues and More
    Kollmorgen Examines Three Design Considerations that Indicate a Machine Needs a Frameless Motor
    Stay "On-Track" When Selecting a Linear Guide System
  • Related Events
    International Conference on Gear Production 2022
    AGMA Involute Spline Design & Rating
George Holling
More from this author
Free Power Transmission Engineering Subscriptions
Subscribe
Subscribe
FEATURED VIDEO
  • Regal Rexnord Motor Minute: Why Do Direct Drive Motor Shafts Have a Flat Side?
March 21, 2022
RECOMMENDED
  • IMTS 2022
    August 3, 2022
  • Virtual Machine Reality
    July 15, 2022
  • The Quest for the Perfect Turbine
    July 11, 2022
  • A Preview of the 2022 Turbomachinery & Pump Symposia
    August 3, 2022
  • Helpline Operator
    August 3, 2022
    August 3, 2022
  • Helpline Operator
    August 3, 2022
  • IMTS 2022
    August 3, 2022
  • Subscribe
  • Advertise
  • Contribute
  • Gear Technology
Powered byAGMA
Copyright © 2022 Power Transmission Engineering
  • Privacy Policy
  • Contact
