An Approach to Pairing Bevel Gears from Conventional Cutting Machine with Gears Produced on 5-Axis Milling Machine
Inho Bae and Virgilio Schirru
Developed here is a new method to automatically find the optimal topological modification from the predetermined measurement grid points for bevel gears. Employing this method enables the duplication of any flank form of a bevel gear given by the measurement points and the creation of a 3-D model for CAM machining in a very short time. This method not only allows the user to model existing flank forms into 3-D models, but also can be applied for various other purposes, such as compensating for hardening distortions and manufacturing deviations which are very important issues but not yet solved in the practical milling process.
Introduction
Recently, cutting bevel gears on universal 5-axis milling machines has been widely accepted as a promising solution to replace the conventional cutting process. The process is highly flexible and does not require special tools. Thus, it is particularly suitable for small batches, prototypes, and repairs in use having unacceptably high lead times. In order to apply the milling process for bevel gear cutting, we should provide feasible solid models. However, the kinematic geometry of bevel gears is relatively complicated in accordance with the variety of the cutting method, such as Gleason (fixed settings, Duplex and Zerol), Klingelnberg (Cyclo-Palloid and Palloid) and Oerlikon, and it’s not easy to generate the 3-D geometry model proper for milling.
In the calculation software KISSsoft (Ref. 1), the geometry calculation of straight and skew bevel gears for standard cone types has been available for many years, in accordance with ISO 23509 (Ref. 2). Then, the expansion to 3-D models of spiral bevel gears was made covering all cone types four years ago. Since the 3-D models of the spiral bevel gears have been available, there has been much interest from many companies worldwide. The first prototype based on the 3-D model was machined by Breton (Ref. 7), one of the major 5-axis milling machine manufacturers, and enjoyed very satisfactory results. Then one of their customers, who is using a 5-axis milling machine, wanted to produce a very large bevel gear pair to replace an existing pair. However, they had a special, hard to resolve problem in that the pinion shaft having a 1,500 mm length was too long to be cut on the Breton machine. So the pinion was produced on a conventional Gleason machine, but the customer wanted to produce the gear (de2 = 500 mm) on the Breton machine. We always recommend to our users that the model for the pinion and gear must be generated by the same software and thus the combination of a pinion, manufactured on a Gleason machine, should not be combined with a gear based on the model. But the customer insisted, so we had to invent something!
We got the basic gear data and the measurement grid points of the flank form of the gear produced by their Gleason software from the customer. However, the design data didn’t include the formal definition of the flank modifications. Thus, the comparison of these measurement points with the 3-D model naturally showed small deviations. The deviation could not be eliminated easily by varying the geometric parameters and applying typical modifications such as barreling (profile crowning) and lead crowning. Thus, we developed a creative solution to generate a 3-D model of the gear and to adapt it to the given grid point from Gleason. In the following chapters we will show the procedure of the method and the application results.
Topological Modification of the Bevel Gear
The basic cone geometry of the bevel gear can be defined in accordance with ISO 23509, and the flank form is defined from the transverse tooth forms calculated along the face width. The trace form will be the extended epicycloid form by face hobbing process or circular form by face milling (Fig. 1). In KISSsoft, the tooth form is supposed to the planar involutes of the virtual spur gear in transverse section. Then, the tooth flank surface is generated by splining the tooth forms of each section.
Figure 1
Figure 1 Face hobbing (left) and face milling (right) processes.
- Click image to enlarge
Bevel gear machine tool manufacturers (such as Klingelnberg and Gleason) have their own methods to generate the tooth form based on the generating motion of the cutter. The tooth form is known as an octoid and is slightly different from spherical or planar involute tooth form. However, the difference of the tooth forms is normally less than the tolerance range and will pose no problem in practical use. This can be verified from the fact that the bevel gears are always produced in pairs by the same process in order to achieve a good contact pattern in practice. In order to validate the practical usage of the 3-D model we compared our model with reference models of manufacturer programs and also carried out the contact pattern check with the actual model. The results showed the tooth flanks along the face width of the two models are very well matched with only slight differences (Ref.3).
One of the most important tasks is to find the optimal modification to give good contact pattern in a bevel gear pair. The contact pattern of the bevel gear pair can be easily optimized by using proper modifications (Fig. 2).
Figure 2
Figure 2 Optimal contact pattern with flank modifications.
There are eight types of modifications available for bevel gears in KISSsoft (profile; crowning; eccentric profile crowning; pressure angle modification; helix angle modification; lead crowning; eccentric lead crowning; twist; and topological modification). The user can define different combinations of modification for drive and coast flanks to optimize the contact pattern separately.
However, if the target modification has highly non-linear or irregular pattern, the simple combination of the conventional modifications cannot be applied. In that case, the topological modification should be used to allow the user to freely define any type of modification that can’t be covered by the conventional modifications. The user can define the modifications in a data map of factors at any position along the face width and along the tooth height by using the topological modification following the convention in ISO 21771 (Ref.4) as shown in Figure 3.
Figure 3
Figure 3 Definition of topological modification in ISO 21771 (Ref. 5).
Figure 4 shows an example of the file structure of the modification used in KISSsoft.
Figure 4
Figure 4 Definition of topological modification and example.
Figure 5
Figure 5 Measurement grid convention of Klingelnberg machine format.
The example data map defines the progressive tip relief on Side I and no modification on Side II. Note that the modification values in the data map are normalized and the actual local modifications are calculated with Ca_ local = fij * Ca, where fij is the modification factor at (i, j) node and Ca is the amount of modification. The intermediate values in between the data can be interpolated by linear, quadratic, or spline approximation along the tooth width and height, respectively.
The adjustment of the bevel gear models to any predetermined measurement grid points should now be possible by applying the topological modification. That is, the modification can be calculated as the deviation between the surface of the 3-D model and the measurement grid points of the target model. The measurement grid points report contains the Cartesian coordinates and the normal vectors of the grid points with the format of (XP YP ZP XN YN ZN). The reference coordinate system of the data is different according to the measurement machines. For example, the reference coordinate system of Klingelnberg format is using the convention shown in Figure 5. The order of the indexes for the points and the sections are defined according to ISO/TR 10064-6 (Ref. 5) as well as the convention from the manufacturers such as Klingelnberg (Ref. 6). Here the index of the lines starts from the root to the tip, and the index of the columns from Side II (heel) to Side I (toe).
In applying the modification, however, various problems have arisen. The definition of topological modification surface in helical gears is located between the tip and the root form diameters, but the diameters over the tooth width for bevel gears are changing.
On the other hand, the effort to transform the measured grid points to the format of the topological modifications is greatly increased. While the measurement direction of the distance between the two corresponding grid points for adjustment calculation is different from the normal of the tooth form (that is, the path of contact) along which the modification is applied. Moreover, even the deviation values are given correctly, we cannot easily reach to the exact surface points because the target modification can have highly nonlinear pattern.
Thus, the procedure to get the topological modification, so that the final model becomes equivalent with the target model, cannot be finished in just a single step but requires rather several iterations (Fig. 6).
Figure 6
Figure 6 Procedure to get topological modification for target model.
Figure 7
Figure 7 Modifications for right flank at Step 1 (left) and Step 11 (right).
In each step, the distance between the corresponding measurement points are calculated and converted into the dimension in the virtual cylindrical gear. Then the topological modification is calculated based on these values and applied to generate a new measurement grid. The procedure iterates until the given acceptance criteria are met. The acceptance criteria are given as the maximum distance between the surface of the 3-D model and the corresponding measurement points is smaller than the userdefined tolerance.
Application and Result
We used 11×7 points for the measurement and topology template definition; that is, 11 points starting from Side I (toe) to Side II (heel), and 7 points from the root form diameter to the tip diameter without margins. The position of each measurement point is defined as the length factor of the path of contact from the root form diameter to the tip diameter (column values in yellow in Table 1) and the face width factor from Side I to Side II (row values in yellow in Table 1).
Table 1
Topological modification for the right flank. Table 1 shows the topological deviation and modification template values for the right flank according to the calculation steps. In the calculation, we set the acceptable maximum deviation to 5 μm.
Step1. In the first step we measure the deviation by the normal distance between the measurement points of the Gleason model with the flank surface of 3-D model (see Deviation 1 in Table 1). Then, we use the Deviation 1 as the initial topological template, Modification 1. The green-colored fields in the table indicate the border of the tooth flank. In our modeling strategy we use a slightly bigger surface area to cover the real gear surface and it’s not possible to measure correct distances at the borders. Thus we ignore the border values in the acceptance checking in the calculation procedure and use the extrapolated values for the values. The maximum distance of the initial step gives 575 μm at the position (0.965, 0.696). The deviation shows relatively big values because we intentionally increased the tooth thickness of the KISSsoft model to completely cover the surface of the target model and to give positive distances. Thus, the final model is compensating not only the topological deviation of the surface but also the tooth thickness deviation of the model.
Step 2. After applying the topological modification of the first step, the maximum distance at the position (0.965, 0.696) reduced to 65 μm and the new maximum distance is 135 μm at the position (0, 0.879) (see Deviation 2 in Table 1). From Deviation 2 you will see the three points at (0, 0.089), (0.522, 0.089) and (0.965, 0.193) have deviations less than the acceptance criteria of 5 μm (values in blue). In this case we use the same topological modification values of the last step at those positions. For the remaining positions we build a new topological modification by linear summation of the deviation of each point and the last topological modification, which is: Modification 2 = Modification1 + Deviation 2
Step 3. Now Deviation 3 after applying Modification 2 shows smaller distances than Deviation 2, and more positions fitting into the acceptance deviation. The new maximum distance is 70 μm at the position (0.965, 0.879) (see Deviation 2 in Table 1). However, the deviation in several positions — such as the positions at (0.956, 0.089) and (0.956, 0.193) — increased because the surface is generated by spline approximation from the topological modification template (values in red). In this case we build a new topological modification from the last topological modification, that is: Modification3 = Modification2 – SIGN (Modification2 – Modification1) * (Deviation2) + (SIGN(Deviation2) + SIGN (Deviation3))/2*(Deviation2–Deviation3).
Step 11 (final step).We then needed to iterate 11 steps until all deviations fit into the acceptance criteria. You can find the final topological modification as Modification 11, and the final deviation as Deviation 12, in Table 1. Now all the deviation values are less than the maximum deviation of 5 μm — except the values at the border.
The graphical comparison of the modification surfaces of Step 1 and the Step 11 (final step) are shown in Figure 1. As you can expect, the final modification surface doesn’t not show a regular pattern, and it’s impossible to achieve the modification by simple combination of the conventional modification types such as crowning and barrelling.
Topological Modification for the Left Flank
After finishing the calculation for the right flank, we applied the same procedure for the left flank. Table 2 shows the topological deviation and modification template values according to the calculation steps for the left flank.
Figure 8
Step 1. In the first step the maximum distance of the left flank shows 570 μm at the position (0.965, 0.789).
Step 14 (final step).We could reach the final topological modification after 14 steps for the left flank. You can find the final modification as Modification 14 and the final deviation as Deviation 15. You can see all the deviation values are less than the maximum deviation of 5 μm, except the values at the border. The graphical comparison of the modification surfaces of Step 1 and the Step 14 (final step) are shown in Figure 8.
Figure 8
Figure 8 Modifications for left flank at Step 1 (left) and Step 14 (right).
Conclusions
The developed method makes it possible to incorporate any desired flank form of a bevel gear given by grid points, and provides the model for the CAM machining in a very short time from the simplest way. That is, the macrogeometry is generally assumed by existing standards or data sheets, and the microgeometry is created by a difference of unmodified real flank-to-the-flank created by topological modifications with the help of KISSsoft. The results showed that the final flank with the topological modification gives the deviation of less than 5 μm, which can be ignored, considering the manufacturing tolerance in practical situations.
The method presented here has considerably high potential for practical usage because it allows not only the modeling of all existing flank forms into 3-D models, but also can be applied for various other purposes, such as to compensate hardening distortions and cutting deviations of 5-axis milling models. These are very important features in practice, and were unresolved issues in the 5-axis milling process.
References
  1. KISSsoft AG. Calculation Program for Machine Design. http://www.kisssoft.ch.
  2. ISO 23509 (2006). Bevel and Hypoid Gear Geometry. http://www.iso.org.
  3. Bae, I. and J. Langhart. “Können 5-Achsgefräste 3D-Kegelräder mit Konventionell Hergestellten Kegelrädern Gepaart Werden?” 2013, Dresdner Maschinenelemente Kolloquium 2013, 135-152
  4. ISO 21771 (2007). Gears: Cylindrical Involute Gears and Gear Pairs — Concepts and Geometry.
  5. ISO/TR 10064-6 (2009). Code of Inspection Practice — Part 6: Bevel Gear Measurement Methods.
  6. Klingelnberg, J. Kegelräder, 2008, Springer.
  7. Breton S.p.A., http://www.breton.it
About Author
Inho Bae, Ph.D,
Inho Bae, Ph.D, received his doctorate in 2002 from Hanyang University in Korea by the research on the design of multi-stage gearboxes. After working as a postdoctoral research fellow at Kyoto University, he moved in 2008 to KISSsoft AG in Switzerland as a development engineer. Dr. Bae is the head of technical support and also working on the development of the KISSsoft and KISSsys software suites.
Virgilio Schirru
Virgilio Schirru was trained as a mechanical engineer at the University of Cagliari in Italy and at the Glasgow University of Scotland. After working for M.g. Mini Gears S.p.a. in their sintering and cut steel department for cylindrical and bevel gears, Schirru joined KISSsoft AG as a support/development engineer
