It's no secret that cycloidal gearboxes are important in mechanical engineering, especially when it comes to precision motion control and efficient power transmission. The gear systems differ from harmonic wave/strain wave gearboxes by using a cycloidal disk and needle bearings to transmit torque with minimum backlash, achieve high reduction ratios, and support substantial loads. This Sumitomo Drive Technologies blog will talk about single-stage and multi-stage cycloidal gearboxes.
The new KISSsoft release 2024 is coming soon! This April will bring you the new system module KISSdesign, accelerating the calculation of complex drive trains and replacing the previous KISSsys software.
IIjin Electric's collaboration with Siemens began with the company's efforts to effectively integrate electrical design with mechanical design. “This collaboration went beyond simply changing tools. It represented a major advancement in the company's design approach and methodology.
With the release of version 9, the FVA-Workbench once again sets new standards in gearbox design, enabling the seamless integration of the latest research results into industrial practice. As a groundbreaking interface between collective research and application, the FVA-Workbench accelerates development and innovation in drive technology. This new release is more powerful than ever, with innovative features for flexible load spectra and improvements in FEM components and shaft-hub connections.
Portescap introduces the 08ECP20 brushless DC slotless motor, a mini actuation solution ideal for engineers looking to downsize devices and applications without compromising on performance or reliability. The 08ECP20 is the smallest frame size to join Portescap’s Ultra EC portfolio.
A calculation platform suitable for all areas of gearbox development
December 1, 2023
Developing a new gearbox series is costly and time-consuming. This is especially true in marine propulsion, as classification society certifications must be achieved in addition to the required verifications. For this reason, Reintjes offers the same drives for various types of ships. In gearbox development, this means that each application requires different loads and usage profiles, with different service lives and maintenance intervals. Thus, each drive must be designed and calculated with advance consideration of every possible profile.
Solid Edge is a portfolio of affordable, easy-to-use software tools that address all aspects of the product development process. Solid Edge combines the speed and simplicity of direct modeling with the flexibility and control of parametric design – made possible with synchronous technology. The following Q&A discusses Solid Edge 2024 with Dan Staples, vice president, mainstream engineering, Siemens Digital Industries Software.
Siemens Digital Industries Software has announced that Plastic Fischer, a social enterprise that works to reduce plastic waste in rivers, so it does not pollute our oceans, has adopted solutions from the Siemens Xcelerator portfolio of industry software to help scale its operations and bring the benefits of digital transformation to its product development and lifecycle management.
A good 20 years have passed since the web-based calculation software eAssistant saw the light of day in the digital world. The software is probably the oldest commercial online solution for the design, recalculation and optimization of machine elements such as shafts, bearings, shaft-hub connections, gears, bolted joints, springs, etc. The calculations are based on internationally accepted standards and guidelines as well as technical literature.
In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
