Nord Drivesystems supports post and parcel distribution centers with modular products adaptable to individual application specifications. Their high-efficiency products increase the energy efficiency of conveyor systems, effectively lowering CO2 emissions and the Total Cost of Ownership (TCO).
Bosch Rexroth and Modine are collaborating to bring Modine EVantage thermal management systems to the Bosch Rexroth portfolio of eLION products for electrified off-highway machinery worldwide. Together, Rexroth eLION systems with Modine EVantage thermal management systems advance the electrification of customer platforms in the off-highway segment by delivering low emissions and high-performance EV technology.
The Factory Automation (FA) Integrated Selection Tool allows customers to plan and configure their Mitsubishi Electric machines, resulting in a downloadable Bill of Materials (BOM).
IKO International introduces its CFC…B Series of short stud-type cam followers. These new cam followers have a unique mounting structure that solves space limitations that often exist on the stud side of the assembly region, thereby satisfying mounting requirements without sacrificing performance.
When it comes to twisting and bunching wire and cable, consistency is key. For example, the amount of insulation required for residential wiring depends on the wire’s lay — the distance between its twists, which is also known as the pitch. Without tight control during the wire bunching process, lay variations occur. As a result, the wire will require more insulation than necessary, raising its cost. A differential gearbox can drive rotating components in a single-twist buncher to provide a more uniform lay, using less power at a lower cost than a two-motor approach.
Igus, a global manufacturer of motion plastics, has developed intelligent two- and four-hole fixed flange bearings with wireless sensing capabilities for wear detection, enabling condition monitoring and preventing costly machine breakdowns.
Caterpillar Inc. has launched a prototype demonstration project for a battery-powered field elevator with Flory Industries, a global leader in the production of nut-harvesting equipment.
Portescap introduces the 08ECP20 brushless DC slotless motor, a mini actuation solution ideal for engineers looking to downsize devices and applications without compromising on performance or reliability. The 08ECP20 is the smallest frame size to join Portescap’s Ultra EC portfolio.
