With the CP150 compact controller, the wait for the electronics to start up again after the engine is shut down for a short time is completely eliminated. This saves time and increases productivity in everyday work. Operators can eliminate the wait and also decrease emissions with the CP150, reducing their environmental footprint. B&R uses the vehicle's battery for the standby function.
Igus has developed a finger gripper for the ReBeL cobot. The ReBeL can now perform a variety of simple humanoid tasks with the new low-cost robotic hand.
Shaft collars and mounts that can be adjusted without tools, plus handles
and thumb screws to convert standard shaft collars to quick-adjust types,
have been introduced by Stafford Manufacturing Corp. of Wilmington, MA.
Stafford Quick-Adjust Products feature the Flip-Lok with a split hub and
an integral adjustable clamp, Staff-Lok Lever-Actuated shaft collar, and
the Python Flange Mounting Collar with a 6-hole bolt pattern and keyway.
Suitable for a wide range of linear and low RPM rotary applications, these
quick-adjust products can be easily repositioned by hand without tools.
Ruland has released mountable shaft collars with face holes for applications where the shaft collar needs to be directly mounted to a component such as a pulley, sprocket, or metallic plate. The shaft collars are available with drilled face holes that give the user flexibility in mounting hardware, or tapped holes that match the standard screw threading of the collar for ease of installation.
Portescap introduces the 60ECF brushless DC slotted flat motor, the newest frame size to join its flat motor portfolio and a significant expansion of its brushless flat technology capabilities. This 60mm BLDC motor features a 38.2mm body length and an outer rotor slotted configuration with an open body design, allowing it to deliver improved heat management in a compact package.
China is leading the world in the construction of solar, wind and thermal power plants to support its increasing demand for electrical energy. For those that use steam turbines, boiler feed pumps (BFPs) are a crucial asset and selecting the best design to suit the needs of an individual station can have many benefits. When a recent project needed some of the largest start-up BFPs available, Sulzer was selected as the preferred supplier.
NSK has developed HTF-SRM Ball Screws, a high-speed, heat-resistant version of its high-load drive ball screws, ideal for high-cycle, thin-wall molding in electric injection molding machines.
Boston Gear recently introduced the next generation of its 700 Series Worm Gear Speed Reducer. The SS700 Gen2 stainless steel speed reducer is an evolution of its first-generation series that has served the food and beverage industry for over 10 years.
AutomationDirect has added more ProSense XTH2 series fixed range, head-mounted temperature transmitters to their lineup of temperature transmitters/signal conditioners. The XTH2 series fixed-range transmitters are for Type Pt100 3-wire RTDs and are ready to use out-of-the-box with pre-configured measuring ranges up to 500°F (260°C).
